1 - 20 of 36 Posts
2018 Outback 2.5i Limited with Eyesight
A2.20.28.20 and maps 1051-7480-10373
Anyone try it ?
I just stumbled through the download to get it on a thumb drive. I'll put it in the car tomorrow.
I'm close to 66y/o, I just find this hard to do.
Reactions: paroxysym
'19 OB SE Premium 2.5 in Dark Pearl Blue with Ivory interior
i found the 50 min wait with engine on for the USB u/g process to complete the worst part, hangs on the map/nav update forever, and needed 32GB USB to fit it all on. so when i updated in June (Rel_UF.20.14.70 EU), i did it when i had a long drive planned, and then when unit rebooted, i managed put my MP3 music USB back in. All good.
Updated ok, but android auto will not connect
On USB port defaults to charging only ...I change it to android auto port and still does not connect
I reset AA and rebooted everything, works now
Just finished the up load into the car. I didn't start the car, pushed the on button twice, turned off the HVAC system put the thumb drive in and followed the prompts. started at 1:55PM, finished at 2:35PM.
Started the car afterwards and let it run for a few minutes.
I sat there and looked through the owners manuals, good thing to do.
I just tried the update. It failed. I tried again, reinstating the USB drive, but still nothing (no percentage countdown, no messages, just a blank screen). Eventually, the software failed box came up.
And now my radio won't restart.
What did I do wrong?
Discussion Starter #11
Try to reload software on a different USB stick. My new ones had problems, the one I use is a 10 yo 16gb SanDisk one
2018 Outback Touring 2.5i
I had a similar problem a few updates ago when I didn't reformat/fully erase a usb stick between updates. Once I fixed that it was fine. I'm using a 32GB Sandisk from a Costco 3-pack.
2018 3.6R Limited nav/eye purchased 8/6/18
Did mine yesterday. Went completely hitch-free. I didn't (never have) run the engine during the update. Took a bit over a half-hour in the car. All's well...
I always do, just go for a long drive..
Reactions: HighlanderUK
Discussion Starter #15
Only problem I had was Waze not opening correctly. Just gets a blank screen. Removed it and reinstalled, same problem
Hmmm... Never used Waze before, but did today (after update). Worked great! Using iPhone, not Android.
I use waze on my phone, I'm to old to figure how the phone will put waze in the car. Waze is free. when these updates stop being free...I'm not paying $200 to renew.
I installed the update yesterday. Much to my annoyance I had the same "USB was unplugged..." error message to start and every time I pressed the "Retry" button. After getting a bit frustrated by the problem, I turned the car off and on again. This time the head unit was able to install the update without any problems. Took about 25 minutes to update. Give that a try if you run into the "Unplugged" problem.
Discussion Starter #20
I just tried waze on my Android phone after I updated to Android 11 and it appears to work fine
1 - 20 of 36 Posts
