1 - 13 of 13 Posts
Does anyone put Marvel Mystery Oil in their Gas or Oil. Ive worked with a few guys who say it really keeps the engine clean to the point it looks new on a teardown. Is it worth using?
Somebody Else's XT
I could see it helping some 100 year old agricultural engines, but it's worthless on anything made since then.
Meh.
I has wagons.
I have heard more folks like it in the fuel, for it's UCL properties, than in the oil.
But I am VERY cautious of any oil additives.
2013 Outback 3.6L Limited with EyeSight
MMO does its best in the fuel tank as it lubricates the pump and helps keep the back of the valves a little cleaner.
...it really keeps the engine clean to the point it looks new on a teardown.
Maybe you should ask them why their engines needed a teardown --
especially when it revealed that everything inside was "like new?"
I've been driving since 1960, millions of miles, and many cars with
200k-plus -- but NONE of those engines ever needed "a teardown."
...a fool and her money are soon courted,
Looby
2011 Prem. 2.5i, 1999 Outback
Check out "bobistheoilguy" site for endless talk about MMO.
Its red.
It smells good.
Its cheap.:)
Never Never Never put any type of conditioner or Oil treatment into your engine. All these are is snake oil..
As far as injector/fuel cleaner I have always trusted BG 44K.
00 Outback Wagon...269K 09 Legacy 2.5 Sedan...93k
It does no harm...but it probably doesn't do much good either.
The ONLY thing it really "hurts" is your wallet...there is no solid particulate in it like others(RESTORE in particular), which you MUST avoid in any vehicle with VVT as they will clog the fine screens on some CPAS units.
As a fuel additive...it's tantamout to the Lucas product, but much cheaper.
What do you care how clean it is in there, if you never have to go there? In other words, what are you trying to fix?
If you have some indication that the fuel injection needs cleaning, Chevron Techron is about as good as it gets.....BMW and General Motors both sell it with their own labels on the bottles. But, if you use decent gasoline, something very close to it is already in there. So, the problem will not come up.
If you have a carbon problem, Techron may or may not help. MM oil may lubricate valve stems. But I have not seen a sticky valve in a regularly operated engine in 20+ years.
The fuel and oil we have available in the present day is much better at keeping our engines clean internally than at any point in the past. With the exception of ethanol, the fuel is flat better than it has ever been......Even if the old stuff did smell better.
2013 Outback 2.5i Premium
I've been driving since 1960, millions of miles, and many cars, with
Looby
Well, I have two years less of driving experience than you, but that set aside, I had never the need for any engine teardown either. And if you consider that nobody in Europe has ever heard of MMO, and that those Mercedes Taxi diesels run for close to 500k miles and all without MMO.
I think that MMO is only advantageous for the dealer and the manufacturer of it. If it would be really great, Consumer Report would have tested and recommended it, like they did with synthetic oil after tearing down several NY City taxi engines for an oil comparison between dino and synthetic..
I do believe that MMO has its place.......In small engines, for lawnmowers and snowblowers, that are operated infrequently. Also good for soaking stuck rings in tractors that have sat for a few years........In a daily driver car or MC engine, not so much.
2016 Outback Ltd 2.5 eyesight Nav push button Hole in roof, Lapis Blue
I did use it a long time back on an older car V8 many miles with oil use issues and felt like it was dieing, I have got to say it did help the oil use and after a short time it did free up the engine a bit and I DID notice it had More power. All that being said I would not use it in a good running engine.
1 - 13 of 13 Posts
