1 - 2 of 2 Posts
Hello! New to these forums.
As I stated in the title, I got my 2007 Outback back from my mechanic (it did have an issue with the air intake that got fixed), but halfway home my tire pressure light came on. I went to use my BlueDriver OBD2 sensor, which had all my dash lights turn on & I received the attached report with many errors. Should I be worried about this? (I did replace fuse 18 after this, but the old fuse looked fine).
Thank you for any assistance that can be provided.
Check your battery and cables. Especially if someone had the battery disconnected.
1 - 2 of 2 Posts
