1 - 9 of 9 Posts
2003 OBW 2.5L 4EAT
I use the M1-108 oil filter (pretty small) on both my Outback and Forester as it is the part number the book at PartSource recommends. I have read about people using the M1-104 (it is the reccommended one for H6 engines) on the H4 engines as well as the M1-110 which is suppose to be a longer version of the M1-108. Which is the best to use to provide the maximum oil filtration?
Fresh Out of Outbacks!
They will both do the same amount of filtration because you aren't changing oil pumps. It's all going to get squeezed through that filter. It's a question of how soon the filter media clogs up and forces the bypass valve to open.
Larger volume = more filter media, longer runtime before the media is clogged and the bypass valve opens on a regular basis.
If you run a short OCI, the cheaper one (regardless of size) will save you money. If you try to stretch out the miles between changes, the bigger one is probably better because it minimizes time on bypass.
2003 OBW 2.5L 4EAT
Actually they are all the same price ($15) regardless of size, so which one do you think would suite the engine the best? I usually do an OCI of 6000 km (~4000 miles). I'm leaning towards the M1-110 since it looks the biggest..
M1-108
M1-110
M1-104
with an OCI that short I don't think volume should be the determining factor. And with cost equalized... it really comes down to which one will spend the least amount of time operating in bypass mode. That might be the one with the most filter media, but the manufacturer may be compensating with different valve springs. There isn't any sort of sensor on our cars (or filters) to report this. With some cars, you can tell by monitoring the oil pressure gauge, but even that isn't always accurate. Sorry to say but I think you're flying blind, and probably overthinking it.
I think the next step would be installing an oil pressure gauge and trying a few filters to gauge results.
also... Seriously? $15 for an oil filter? :gasp: I just paid about $2.85 apiece for mine, including shipping.
2003 OBW 2.5L 4EAT
Wow :gasp: I thought that was cheap compared to the Suby dealer near me that sells the oems for $22. Where are you buying yours?
What type of oil pressure gauge do you reccommend and where is a good place to buy one?
Even if I don't get a gauge now I might try out the M1-110 with synthetic oil. What is the appropriate mileage I can get out of it?
There are two basic types of OP gauge- mechanical & electrical. The mechanical ones involve running an oil line from the engine up into the cabin where the gauge measures it directly. Probably the most accurate kind, but they are a hassle to install and a disaster to clean up from if something leaks. You don't usually put them in anything but race cars.
The electrical ones have a sensor that converts the reading to electricity and then sends the info up a wire. You get way more flexibility on where to mount it.
For my money, VDO makes the best ones, but there are numerous quality brands out there. The usual hassle is figuring out where to mount it. I have yet to install one in my own subie so I don't have advice for you there. For my year/model I appear to have the option of getting an OEM model but it's very expensive.
Keep in mind that even with the gauge, you may not be able to detect bypass condition in the filter. It's obvious in some cars and not in others. If you really, really care about your oil it's a nice thing to have anyway.
I bought Mann brand filters from rock auto. I've used them on lots of other cars, came to trust them. Previously I was using the blue OEM Subaru ones, and I was buying them from a local indie shop for about $6.50.
Regarding OCI mileage... if any of your cars are still in warranty, change it as often as the manual states to protect your warranty. I think this is 7500 miles but read your manual to make sure.
After the warranty is up, get a used oil analysis and see if they say it could run longer. Then make the judgement call. If you run it 7500 miles and the lab says the oil is still in good shape, maybe try 10,000. The longer you run it, the more you save. If you aren't into checking the level between changes, then extended runs are not for you- don't try it.
You can use the lab report to tell you if you should consider changing the filter in between oil changes. At the end of the day, it's your engine and your checkbook.
2003 OBW 2.5L 4EAT
Thanks for all the help and info, I always look forward to learn something new. I'm pretty meticulous about car maintenance especially with the Subaru's, so i'll definetly be checking out my options for oil gauges and probably install one in the spring and i'll be saving my money oil filters as well :29:
Wow :gasp: I thought that was cheap compared to the Suby dealer near me that sells the oems for $22. . . . .
$22? I don't understand how it can be that expensive. The over-the-counter list price for the 2.5 NA Subaru filter at dealers up here (eastern Ontario) is about $7.50.
2003 OBW 2.5L 4EAT
I was told by the service guy that they cost $22 when I took the Forester in for a synthetic oil change about 2 years ago. I guess they were trying to make the service seem cheaper... and I foolishly believed him. I'll go see how much they actually cost at the parts department sometime.
1 - 9 of 9 Posts
