2009 OB 2.5i 4EAT
Hey folks, gonna replace my bulbs tomorrow and polish up the headlights. Also need to address the moisture that I've seen in my left headlight.
I suppose the obvious culprit is where the main bulb is- so I guess check to make sure it is seated properly and that the boot is intact. Anything else I should check for?
Watch this guy's video, it's pretty good. And take care to heed his advice to watch out for the bulb retention mechanism, it is pretty fragile.
http://www.subaruoutback.org/forums/80-electrical-electronics/406618-2005-2009-low-beam-headlight-bulb-changing.html#post4660714
To our specific question about moisture: It's not sealed with a boot, it's a plastic protective cup in back of the bulb. Check the O-ring surrounding this plastic for integrity, and when you put it all back, be sure to lock it in place.
2009 OB 2.5i 4EAT
Perfect, thank you!
