A second pic....
It was mid to upper 40’s outside. The car was not garaged that night either. I honestly feel it was a defect and do not believe any rocks or other debris hit it, but it was very dark out and hard to see. Also, the inner cover was closed, thankfully.It'll be interesting to follow this one. Was it cold outside? Do you have any "gut feel" thoughts on this?
No bridges/overpasses.Did you go under any bridges?
Sent from my Nokia XR20 using Tapatalk
The median is huge where I was so I’m thinking it probably wasn’t from cars the other way. It really is rural where it happened, and literally the only car around was right behind me. I really could see it being a rock that hit me yesterday, a week ago, or even a month ago that I didn’t notice. I could definitely see that.My gut feeling about these things is that tiny rocks can create tiny pits in glass without causing breakage immediately (my windshield has at least a half dozen small pits that you can't see without close examination after feeling them) and then these tiny pits are a weak spot that either thermal cycling or another tiny impact can cause the shattering/cracking. Our windshields are laminated but it appears that the sunroof glass is tempered instead.
Looking at the image of the sunroof glass, it looks like there is an origin for where some of the cracks seem to originate. If there was traffic in the opposite direction a small rock may have been flown your way.
If the glass were laminated it would hang together better but then I suppose there's a chance that a big piece might fly off the car and hit someone else instead of just tiny fragments.
A second pic.... View attachment 558143
I bet it something that has to do with air pressure inside the vehicle that what could have caused it.A second pic.... View attachment 558143
Odd, I never got the memo on this one. So steel = “sunroof”, glass = “moonroof”?I often wondered why they did away with the old metal moonroofs (then called a sunroof.)
Frankly I do not know, but I remember when the terminology appeared to change. In the 60's and 70's (at least with German and some other European cars) they were sunroofs, and most of them were sliding steel with cranks to open them (some had to be pulled back), even on a lowly VW Bug after the early 60s (early 60s Beetles and other Euro-cars often had canvas). The Citroen 2CV has a great big full retractable canvas roof. We used to ride around with our heads out of the VW Beetle sunroof like tank commanders by sitting on the front seatbacks. Also keep in mind that back then AC was often an option and sometime even a bolt-in dealer or after-market option and not universal like climate control.Odd, I never got the memo on this one. So steel = “sunroof”, glass = “moonroof”?
