1 - 11 of 11 Posts
2004 Outback Wagon
2003 Outback 4 cyl automatic
New timing belt, water pump etc 1 year ago.
60k miles.
This was my father in laws car and he did not take the best care of it.
The car has been running hot lately.
Coolant levels look spot on and the thermostat is good.
Both electric fans work.
Took it for a 35-40 minute trip today in 20 degree Fahrenheit temp and it ran VERY HOT. Seems the faster you drive (70-80 mph) the hotter it gets.
Slow down to 55mph and eventually the temp guage comes down.
At idle with both fans running it finally came back to a normal range.
Thoughts ? Head gasket going south ?
Looking for some input.
Might as well do the head gaskets since they're going to fail anyway. See if the coolant is clean or murky.
Could be HGs, could also be thermostat. Super easy to change, use a Subaru OEM from the dealer. It's a good starting point and cheap as well.
2001 outback 2.5 i
On what you have told us the head gaskets would be a long shot . Firstly it is 2004 mod which has a rare ocurance of head gasket failure .
Some things to check first
Radiator cap
If radiator is clean
If heater core is clean . Try bypassing it and check if the bottom radiator hose is cold when engine is overheating
Let us know the answer to those and we might get closer to a remedy
'02 Bean H6, AWP & ORP, factory hitch
Look in your manual if you have it and check the coolant capacity of the car. Do a flush and then refill and see how it compares with the spec in your book. Check your tailpipe for excessive moisture while running. That is one good way to see if your head gasket has problems. Also you can run a compression check. Bad gasket/lower compression sometimes. Start with the thermostat and water pump first. I'm sure the replies before mine come from knowledgible folks! Good luck!
2004 Outback Wagon
Putting in a new Thermostat this A.M.
Will drive and advise.
Noticed drivers side head gasket has some weeping / oil looking residue on the bottom of the head where it mates with the block. Passenger side cylinder head is clean of any weepage.
Oil pan gasket is leaking as well.
Coolant was very clean when I drained it down last night.
Just have to install the new thermostat after I finish here on the computer.
Wish I had a Subaru tech close by and looking for some side work.
Deming
2004 Outback Wagon
FIXED. It was the original thermostat and apparently goping bad.
I installed a new thermostat and that fixed the issue.
I am sure it will need new head gaskets in 25-30,000 miles, so I can save some $$ and look for a qualified independent mechanic that is knowledgeable with Subarus.
Thanks for all the input. Very helpful !
2003 OBW 2.5L 4EAT
How many miles does your Outback have? I hope my thermostat doesn't go south as well since I still have my original one at 125k miles.
2004 Outback Wagon
Yeah seems to be running pretty well and staying cool.
Drove it most of the day today. So far so good!
It is a 2003 Outback with the 4cyl "SOHC" 2.5 motor and 60,000 miles.
We inherited it the car and it had a tough life.
I know if will need head gaskets down the road.
It was the original thermostat and the new thermostat seems to have fixed our issue.
Happy face on this end! :D
03 Outback H6 base
Don't forget to add some Subaru OEM coolant conditioner. I believe they recommend 2 bottles. It's cheap insurance.
2004 Outback Wagon
Discussion Starter · #11 ·
I did not install the Subaru coolant conditioner.
I was really hoping to find a Subaru tech, in the midwest, who was looking for a side job.
Ideally, I want to get the cyl head gaskets, valve cover gaskets and the oil pan gasket replaced. The heads will need the machine shop treatment while they are off the car.
This 2003 Outback only has 60k, but her dad was pretty hard on the car.
PM me if you know of any good Subaru techs / shops in Iowa, Illinois or Grand Rapids.
Deming
1 - 11 of 11 Posts
