2006 Outback XT 5 speed
Exactly what my 06 did after the brake line recall "fix" failed and the lines rusted through. I was able to get SoA to cover half the repair at the dealer after several phone calls and escalations.
2012 OB , 2017 Impreza
yup... that is jut below where there is a 'splice' in the brake-lines. Dirt collects, holds moisture (and salt if you live in NorthEast)... the metal brake-lines start leaking.
Beware of rust just behind the rear doors. If you open each rear door, the rust likes to make holes between door/wheel if that area (BEHIND the metal) is not kept hosed out.
