Hi there
curious if anyone knows what window motor is needed for the passenger side window?
is any recent ‘09-‘15 motor compatible or does it need to be specific to the year of the car?
thanks
Outback 2011 3.6R Premium
I do not know the answer to your question as such BUT typically the window winders are the same across the generation of the vehicles.
If you put your VIN number into the partsouq.com website you will be able to determine the part number of the window winder you need which may help when searching places like eBay for used parts.
You can also order from partsouq.com
Seagrass
Seagrass
Thanks for pointing me in a direction, will look into it.
cheers
