Hello all,
I picked up my first Subaru a bit over a year ago, and it's been great aside from one ongoing issue, which seems to be getting progressively worse. The car is 100% stock AFAIK
A little history..
When I first bought the car, it ran a bit rough at idle occasionally but nothing unbearable. This still happens. It also seemed to have a hesitation around 3k RPM under almost all throttle conditions (full throttle, part throttle, cruising etc). This hesitation seems to happen before boost really kicks in.
About 2 months ago, I started getting misfire codes and brought the car into a mechanic. After a few days of diagnosis they identified a vacuum leak in the form of a cracked intercooler, which I had replaced.
The car ran well after that, but still had the hesitation/stumble (feels like a misfire, or flooding) between off boost and on, around 3k RPM.
Very recently now, the stumbling has gotten worse (much worse) and I am also getting a P0244 CEL that is usually triggered at or near full throttle, under load. I've noticed it usually at higher RPMs, around redline. Sometimes it happens between shifts, but not always.
The mechanic had advised a transmission fluid flush before these problems developed, but I don't imagine that would cause this issue?
Any ideas on what might be going on here? It sounds a lot like several other threads I've read on tuned cars, but not necessarily in combination with the off boost stumble?
At any rate, happy to be a new Subaru owner and hoping I can work out this last gremlin.
A little history..
