1 - 20 of 49 Posts
2020 Outback Limited XT
I ignored the fact that my Subie seemed to lean to the left when setting in the garage. I figured the floor had a little slant to the drain. Well I finally decided to check. Yup the left side is 1/2" lower than the right. I measured at the wheel well, and to the bottom of the door handles. Bringing it in today to get it checked out. They'll probable try to blame it on the heavier duty sway bar. but it was tilting prior to me installing it.
Will let you know what the outcome is later.
2012 Outback 2.5 Premium - Former: Golf TDI
Good luck; this is well documented in other areas of the forums and there's practically nothing they can do about it; in fact, they'll take you out to the lot and show you how basically every other one does this and just ignore it.
It bugs the **** out of me in the garage where I have a straight-line frame of reference, however any other time I don't even notice it
2012 Subaru Outback 2.5i Limited
My 4runner leaned. My G500 leaned. My friend's Lexus GX leaned.
2012 Impreza Sport Ltd 2013 Outback Limited SAP
Maybe you should have purchased a 2012 rather than a 20120.
2011 Outback Premium 6MT
Maybe it is to compensate for the weight of a driver as sole the occupant.
Your 4 runner probably leaned rearwards as well. They all look like they are doing wheelies. Did Toyota put a bunch of bad springs in these vehicles?
2013 Outback Limited 2.5 EyeSight & 2010 Legacy Premium, 2010 OB Limited (traded)
That must be it but they forgot to switch sides for the US market being the driver sits on the left and the sag is on the left.
2018 Outback Limited 2.5i Dark Blue Pearl/Ivory w'Eyesight
Heavy steering wheel?
The center of the road is higher than the shoulder. The lean compensates for the crown of the road so the car drives level.
The Box of Sees Candy under your seat for those emergency snack attacks could be the culprit or possibly the Jumbo 32oz fruity slurp in the driver side cup holder. ;-)
2019 Jeep Rubicon Unlimited
Perhaps it's deliberate to compensate for the slight tilt to the right most roads have, to facilitate drainage?
Maybe they were inspired by NASCAR...
Edit: Maybe I should have read upflying's earlier post before making this one...
Discussion Starter · #18 · (Edited)
Well, as the other article pointed out here, a lot of others have the same problem. The dealer says they measured on their very level garage and saw no difference. Put it up on the rack and said no leaking struts, etc. Said maybe my garage floor tilts!! Well the car still should show the same measurement from the floor to the top of the wheel arches I would think. Anyway, forgot to back it into the garage to see if the sag reverses. Bet it don't!!! Will let ya know how that works out later.
LATER
Backed it in the garage, no difference! Even measured from the floor to the area you use when jacking it up. Also 1/2" difference. I really don't know what to do about this???
Black 2010 OB 2.5i Premium CVT
"Better then the right" is what i always say! LOL
Holy crap...
2013 Subaru Outback Limited 2.5
See two post like this.. That may be a correct statement in the design. It would end up tracking straight on a road with a crown instead of wanting to drift toward the right as most cars would..... of course that is just a theory...
Of course it could also be so it's easier to grab that 1000 calorie milk shake at mcdonalds, and the weight of the driver has caused it to sag in the process... :D In that case you need the optional kryptonite springs!
1 - 20 of 49 Posts
