My 2008 Outback history. I am 1000 miles and a week or two from passing my 5yr/60K powertrain warrenty. I hope to have dealer check over everything just as a precaution in case I missed anything. I do all my own maintainence if I can. It has only been back to the dealer once for a leaking radiator hose clip when it was new as far as warrenty reapairs. And a TSB for a computer update of some sort. Now a clip on the rubber trans line is wet and I ll have them tighten that up. Everything thing else is dry.
Synthetic oil every 6-7000 miles.
40K wheel alignment when buying tires.
42K, Spark plugs, air filter, coolent flush, brake fluid flush, trans fluid, cabin filter.
50K, AC condenser drain line clogged, blown clean.
59K, brakes and rotors, new battery.
I have been concered about the dreaded HG leaks and just inspected from underneath the car and everything is dry.:29:
