· Premium Member
2000 Outback 2.5
Hi i just did the head gaskets on my 2000 OB 2.5 had coolant in the oil. I now have a small leak dripping on the exhaust and cross member it isnt from the heads and i changed all the gaskets , oil pan ,valve covers, rear main seal, and even while underneath I cant seem to find my leak. pcv valve is new hoses routed correctly etc. Anybody got an idea?:confused:
Bump .... Good luck crazy bull. I have a 2001 legacy outback sedan, I am trying to update/upgrade what is needed to help her run healthy and prevent future problems. Give me a shout if you have any questions, sorry I couldn't help you with this though.
2001 Outback AWP 2.5 - 2005 Outback L.L.Bean 3.0
What about all of the valve cover bolt grommets and spark plug tube seals?
I replaced those on my wife's '01 and stopped a pretty significant leak that wasn't stopped by valve cover gaskets alone.
· Premium Member
2000 Outback 2.5
Yes I replaced the valve cover gaskets and grommets and tubes, the oil separator is a metal one and was dry as could be. I saw no leaks in the bell housing area at all when the engine was out. Even now the area is dry as far as I can see I just dont want to pull it back out unless I have to, Thank you all for the information.
