Nav Map orientation
6204 Views 5 Replies 5 Participants Last post by  BillCas
My 2013 Outback nav map needs to be rotated 180 degrees. The map is fine but the direction arrow (cursor) is pointed down. How do I get the arrow to point upwards (I'll say in the direction of travel) so that the map is correctly oriented to the landscape that I am passing.
Also what do the different colors indicate? I got the blue for water but what are the green, brown and ruby red colors? they don't seem to identify with the passing landscape.
Under nav settings, change it from North to Top
Do you know if this is an option in a 2020 Outback? I can't find it and want to change default as well. Thanks,
I hope there will be an update for this. This is two of my 8 touch screen selections that I need to make every time I start my 2020 Outback. Ridiculous that I can’t store in my profile.
I tried today and could not find the option you referred to. Any suggestions?
The 504 update fixes the issue. Orientation stays with what was selected last.
Too bad it is not the same with AVH and the engine shutdown.
Reactions: 1
