1 - 8 of 8 Posts
2005 Outback
I'm looking for a utility trailer that is light enough for my new 05 Subaru Outback. Is anyone aware of a Canadian (Ontario) manufacturer for one? I understand the Sub can only tow 1000 kg. max without trailer brakes.
Thanks,
Dan
MY04 OBS
Hey Dano,
Try Marine Cradle Ride (in Markham I think).
They custom build a ton of trailers, and might have something you can use.
2005 Outback
Sub trailer
Thanks, I'll check them out. Someone on another board suggested one sold at Costco and made in Canada. Can't find it on the Costco website and I'm not a member. Have you heard of this one? He thought it was called "White Bear".
Dano
2005 Outback
Sergeant:
Marine Cradle only sells boat trailers.
I also just realized that I said the '05 could tow 1,000 KG. It's actually only 1,000 lbs -- that's a big difference. The weight of the utility trailers at Home Depot, Snow Bear, etc. is around 500 lbs. which doesn't leave much room for even a half cubic yard of earth.
And none of the utility trailers come with brakes!!
Looks like I'm SOL.
Dano:(
Dano said:
Sergeant:
Looks like I'm SOL.
Dano:(
Are you sure about the 1000LBS towing capacity? Because my owners manual for a '97 OB says 2000LBS w/o brakes... and I've tested it... just might be worth another look, I'm pretty sure the XT can do 3000LBS
enouen
Harbor Freight sell some inexpensive utility trailers. Check their website for some details. I believe some assembly might be required for some of them though.
'05 3.0 R LLBean
FYI...From my 3.0 R Owner's manual
When towing a trailer without brakes. - 1,000 lbs (453 kg)
When towing a trailer with brakes. - 3,000 lbs (1,360 kg)
When towing a trailer on a long uphill grade continuously for over 5 miles (8 km) with an outside temperature of 104°F (40°C) or above. - 1,500 lbs (680 kg)
:)D ...yea, and when there's a full moon on even numbered days?... ;) )
that's CRAZY
Enouen
1 - 8 of 8 Posts
