1 - 8 of 8 Posts
If you own a 99 Legacy Outback I would appreciate it if you can check something for me.
There is a spec number on the transmission casing. It might be difficult to see, but it is on the left hand side (Vehicle left) under the slave cylinder. It is on a white piece of paper and should read something like 68-TY754VCACB. There might be another number just above it. Please check and let me know if the number on yours is the same as mine.
TIA
Tokyo's between my toes
2001 Wintergreen Outback 5MT
My 98 has this:
96-TY752V2DCA
On a separate paper tag nearby, there is:
152705
And on the passenger side, molded into the tranny housing:
JAPAN FM-B
Cool, THANKS Alex!:29:
Now I just need one from someone with a 99 OB to make sure it is the same.
i have a '99. i'll check the number and post it as soon as it's light outside.
just out of curiosity, what are you checking for?
I had some suspicion that the transmission had been changed and was not the correct one for the car. I have since verified with Subaru that I indeed have the correct one in the car. If you do check yours, your number should be the same as mine.
*G* yeah, better check, because transmission-swapping is becoming a common crime in many cities....
So, any pics yet? I want to see guts, I want to see teeth.
...wait a second, that sounds like something on some weird animal-predation site...
Found the download cable for the camera this morning. Give me a day or 2.
I take the card out of the camera and put it in a reader on a USB cable
1 - 8 of 8 Posts
