Gen 6 Outback Silver's NEOMAX Coilovers with Swift Springs
  • Like-new - used for only 1000 miles, moving to a more rural area in Canada with non-paved roads where coilovers are unfortunately an inconvenience, especially during winter.
  • Swift springs rates are 6K Front and 8K Rear.
  • Drives like a sports car, looks so planted and beautiful (Lowered mine about two inches but can go lower than that, See photo).
  • Paid close to $1700 USD
  • I'm also including a a pair of adjustable endlinks worth $150 USD
  • I live in Vancouver Canada and can arrange shipping anywhere in US and Canada, I will cover up to $100 USD of freight.
Check out the specs:
  • Adjustable T6 6061 front camber plates.
  • Koyo Japan Radial Bearing upper spring perch standard. This eliminates spring bind, noise, and gives improved driver feedback.
  • 24 levels of damping adjustability combined with our high grade shock oil, not only do you feel the click in your fingers, you feel every damping adjustment in the driver’s seat.
  • High strength JIS G3445-STKM13C (DIN2393-ST44-2) carbon steel 52mm diameter seamless shock tube.
  • 44mm piston with digressive style valving characteristics provides maximum low speed damping response for ultimate performance while simultaneously giving a comfortable ride.
  • Mono-tube shock design, Increases shock oil capacity as well as displacement over twin tube designs for maximum performance.
  • High viscosity IP F.A. 5W damper oil ensures the best efficiency and consistency of shock-absorption and damping control.
  • Height adjustability is provided by the lower bracket which prevents the need to adjust the spring perch or preload, offering the maximum possible travel regardless of height setting.
  • Powder coated steel lower brackets matching all factory brake line & ABS wire tabs, for seamless installation.
  • Anodized T6 6061 aluminum lower mounts for multi-link suspension systems to lower unsprung weight.
