1 - 9 of 9 Posts
I changed my clutch on my 2002 Outback...can't get it to go in gear unless it's turned off. Any suggestions?
Discussion Starter #2
Got a good pedal....just won't go in gear. Looked at the rod on the slave and it's like it's not wanting to extend...it extends very slow. Maybe the slave cylinder is going bad?
2001 2.5 RS & 2000 OB
It's possible that the flexible line from master to slave is going bad. Did you bleed the clutch system?
The lines look good....no evidence of leaking. I did bleed the system....I know..they're hard to bleed. I'm wondering if my slave is going bad....no evidence of leaking, tho.
2010 2.5 CVT Premium
I recall another owner had a similar issue recently which turned out to be a broken clutch fork.
1 - 9 of 9 Posts
