Time to replace what's in there now. I'm looking for something in amber, doesn't cost $30 but definitely gets the job done. Any suggestions, comments?
Find em at Autozone, Advance, etc.? Or do they need to be ordered?Bang for the buck, I've had good luck with my Nokya fogs. $20 for the set of two.
Following advice from Jogosub on this Forum, I changed my four turn signals to Nokya Hyper yellow bulbs, which I got from Amazon.Find em at Autozone, Advance, etc.? Or do they need to be ordered?
I also did this and could not be happier. I can't tell you if those numbers are compatible with GEN3 though.Following advice from Jogosub on this Forum, I changed my four turn signals to Nokya Hyper yellow bulbs, which I got from Amazon.
4x Nokya 7440 20mm Hyper Yellow 21W
Sold by DC Autoparts
Condition: new
In addition I replaced my fog bulbs with Nokya hyper yellow, but at the time the proper size wasn't available from Amazon, so I got them from Auto Car Performance Parts | Auto Accessories | Aftermarket Auto Parts. I added heavy duty harnesses as well.$27.80
NOKYA Hyper Yellow Pro NOKYA-HB-YELLOW-NOK7618
Wire Harness Option = With H11 Halogen Light Bulbs
Plug-N-Play Wire Harness (+$15)
(Stage I, H11)
I think they look great.
So did I - I put the Nokyas Hyper yellows there....I use Nokyas everywhere... I hear rumours that some disgrunted PIAA employees started that company a while back....to compete with PIAA and their ridiculous pricing!Bang for the buck, I've had good luck with my Nokya fogs. $20 for the set of two.
Thanks for the credit Budaru ... I see I have some "positive" impact on this forum after all....I also did this and could not be happier. I can't tell you if those numbers are compatible with GEN3 though.
I'm thinking about doing this, since my wagon needs both foglights. With new lenses I think it'll be best to run HID bulbs for the yellow light and not laminx. Hows the light coverage on the ground look? could you compare it to stock in any way?I'll be honest, I spent a little more ($50 for the pair) and got 3000K HIDs for my fog lights. I specifically went for putting them in the fogs because they flood the road with light, and I can turn them off when I don't need them so I don't blind the **** out of oncoming drivers.
