Hi, new to the forum.
I just purchased a 99 legacy outback limited with 179K for my son to take out to Colorado for a seasonal job that he has.
I have been fixing some of the things I saw in it before purchase, that is how i got it for under $3K.
This is what I have fixed:
New passenger side CV axle - torn boot.
New brakes & fixed seized calipers.
New spark plugs. - wires good, no need to change
New Serp & V belts.
New battery.
New pcv valve.
Checked coolant integrity - good.
New Knock sensor - threw a knock sensor circuit code.
Speedometer intermittent - removing speedometer and resodering joints to see if that helps.
I have also checked the head gasket and don't see any leaking, blue/white smoke from exhaust, brown or cloudy coolant, overheating after long run times or irregular idling. does this mean that the gaskets are still good?
I also have a broken driver side timing belt cover, does anyone know where I could get a new one or is it ok to run without one side on?
Is there anything that i may be missing to check on the car before he drives it from MI to CO?
Any help would be great.
Thanks.
I'd Change the timing belt and all the goodies behind the covers while your at it ... Cheap insurance and a fairly easy task :29: , id also flush the coolant anyways and put a new radiator cap and factory thermostat in it
Thanks.
I forgot to mention i am replacing the fuel filter also.
Is there a brand of kit i should look for or stay away from, Dayco, Gates, AC?
I am running out of time quickly on this so I need to make a decision as to whether or not I am going to try and do this, about how long would the timing component replacement take?
I like gates , but prefer napa over most .... Napa carrys Gates :29::cool:
