Looks like you got it under control. There are a ton of other little things to worry about, but you got the big ones. Check the CV boots regularly. Follow the DIY to change the boot when it breaks (should be about now).
Check the rear LCA bushings. They are usually torn bad. Common symptom is 'vague' steering feel. You should replace all 4 shocks. Use the 00-04 KYB in the rear.
Make sure you check your oil every fill up. This turbo will eat it at random times and random amounts.
