1 - 20 of 65 Posts
Supporting Vendor
2015 STI
Our SS3 LED Fog Light Kits are now available for the 2013-2019 Subaru Outback! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic in the SS3 collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
While these outdated optics lose up to 10% of the light output shining through an outer lens, the SS3’s custom-molded TIR optic functions as both the optic and the main lens, dramatically increasing the amount of usable light output.
Functional Output: All SS3 LED Pod beam pattern options were designed with optical simulation modeling, to shape the light output in a highly-functional beam pattern. Making it a perfect option for your factory fog location! We offer these kits in two SAE-compliant optics:
  • Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
*When installed as a pair and aimed in accordance with your state's regulations, the Driving White pattern meets SAE J581 standard as a Driving/Auxiliary High Beam Light, and the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use. Please check your local laws and regulations for aiming, installation, and applicability.
White or Yellow: Our SS3 LED Pods are available in your choice of 6000K cool white or 3000K selective yellow. The white is a 6000K color temperature, which is a true white output, without any blue, and is a perfect match for most OEM LED lights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a totally unique look on the road.
Sport/Pro/Max: Stage Series LED Pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The sport model uses high-intensity LEDs and is the best bang for your buck you’ll find. The Pro steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, both for high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2013-2019 Subaru Outback includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
Each kit will include:
  • Two (2) SS3 3” Standard LED Pods
  • Two (2) 9006 DT Adapters
  • Two (2) H11 DT Adapters
  • Two (2) Type OB brackets
  • Mounting hardware
  • Mounting guide
Note: This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
Proven Reliability: Our SS3 LED Pods have been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like OEM components!
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
Supporting Vendor
2015 STI
I finally replaced my factory fogs with a set of SS3's. Love them! Should've done it sooner!
We're happy to hear you're loving your SS3 LED fog light kit on your Outback! Thank you for supporting Diode Dynamics!
Did you go with the sport, pro, or max? Which color output? 😎
John C.
Diode Dynamics
2015 3.6R Limited w/ES
If you guys can figure out how to permanently disable the steering-responsive fog light feature on early Gen 5s (2015-17 I think), you'd likely have a sale here (I'd only go MAX, and I would assume they're way too bright to have them coming on accidentally). I suspect it may simply be a matter of getting to the relay in the dash but haven't investigated yet.
Edit: not so simple it seems:
Supporting Vendor
2015 STI
Unfortunately, we do not have any information regarding disabling the steering-response fog light feature. Sorry about that!
Please note, the SS3 Max LED fog light kit when installed and aimed in accordance with your state's regulations, the Fog pattern meets SAE J583 standard as a Foglamp, for legal on-road use.
SS3 Max (White) Data Sheet:
SS3 Max (Yellow) Data Sheet:
Please, feel free to let me know if you have any other questions. I'll be glad to help!
John C.
Diode Dynamics
Yep, I realize they're "legal", but I'm of the opinion that anything dramatically brighter than stock should absolutely not be used in the presence of oncoming traffic, regardless of how carefully they're aimed.
Supporting Vendor
2015 STI
OK! We refer to established standards and laws which specify the amount of light that can safely be shined to the road, but I certainly understand your opinion.
I wonder if anyone else may know a solution for that responsive cornering/fog feature?
Supporting Vendor
2015 STI
Discussion Starter · #10 ·
Our July 4th Sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our newly released SSC1 LED Pod, by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
Supporting Vendor
2015 STI
Discussion Starter · #11 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our newly released SSC1 LED Pod! Don't wait, this sale ends TONIGHT!
John C.
Diode Dynamics
Supporting Vendor
2015 STI
Discussion Starter · #12 ·
In this video above, we compare our SS3 LED Fog Light Pods to other market-leading fog lamps! We break down each fog lamp by intensity, beam pattern, color temperature, and price.
For this comparison, we've used our state-of-the-art Goniophotometer, a device that measures multiple points to calculate the intensity and map out the beam pattern of each fog lamp! We've also used our integrating sphere, which is a device that is used to measure the color temperature of each fog lamp. We hope the data we collected helps you choose the best fog lamp for your vehicle.
John C.
Diode Dynamics
Administrator
I know you have a Driving light / Flood combo..
Always pondered how a Driving Light / Fog Light combo would behave.
Supporting Vendor
2015 STI
Discussion Starter · #16 ·
Darn missed the sale, but these look awesome. Great reviews on YouTube on the strong cutoff and optics.
Any chance another sale is coming soon? I'm ready to order.
Hey guys!
Yes, we will be having our Labor Day Sale this year. Stay tuned!
John C.
Diode Dynamics
Supporting Vendor
2015 STI
Discussion Starter · #18 ·
Hey, you have meanwhile increased the price by $20, is it a preparation for the discount?
We are doing this to account for inflation and to offset the higher costs of materials/shipping seen in today's market. This is the first widespread price increase in our company's history. While our competitors have implemented prices increases over the years, we have tried to keep our prices consistent. With all of the in-house engineering and manufacturing that we do now, this is a necessary action to ensure that we have the capital needed to keep bringing awesome products to market.
John C.
Diode Dynamics
Supporting Vendor
2015 STI
Discussion Starter · #19 ·
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our SS3 LED fog light kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
1 - 20 of 65 Posts
