1 - 8 of 8 Posts
Picked up an 05 XT with 77,000 miles about a month ago. Now the ABS light comes on with error code SS or 55. Always resets itself on the next drive cycle. Can come on in a matter moments or after an entire day. Have tried to search but didn't come up with anything. Can anyone shed some light on this??
Thanks,
David
The "ErSS" that appears in the instrument panel trip meter is indicating a LAN communications problem related to a wheel speed sensor. Basically, it's saying that either there's no wheel speed sensor signal, or the signal isn't what it should be. The ABS light is lit indicating that the ABS is not working, because without reliable wheel speed signals the ABS system can't function; consequently, it is automatically disabled when this type of problem arises.
There might also be one or more ABS system trouble codes related to that speed sensor. A trouble code would be generated, for example, if the connection between the ABS controller and a wheel speed sensor is open or short circuited.
Wheel sensor signal problems sometimes are due to dirt accumulated at the wheel sensor, preventing it from picking up magnetic signals from the spinning wheel hub. It can also be the result of a replacement wheel hub not having the proper magnetic strip to signal the sensor, or improper installation of the sensor.
Intermittent problems can be a challenge, but if the ABS light is on, a Subaru dealer, or Subaru specialist shop, can use the Subaru diagnostic tool (Subaru Select Monitor) to read whatever ABS codes might be stored. That might identify which wheel is involved, allowing for more focused examination and/or troubleshooting.
I'm not aware of any other way to read the ABS codes on a 2005.
Hope this helps. Others will probably contribute more . . .
There ar some shops that have a scan tool that also does SRS and ABS codes. It may be a less expensive alternative to the dealer. Also if you are handy, these type of scan tools are more pricey, about $300 or more, but worth it if you plan on working on your own cars.
Otherwise Plain OM is quite right, Many factors are involved. I'd recommend retreiving the code(s) before anything else
Wes
· Meh.
I has wagons.
Where are you?
Most autoparts stores will read the codes for free in the US (except California). Get codes, post them here in a new thread.
Fresh Out of Outbacks!
There is a built in code reader on your car. This thread details how to use it.
Please note- the instructions are for 2006-2009 cars, but in post #15 you'll find the slightly different method required for 2005 cars.
Also I suggest you stop driving the car until you've seen the codes. Especially because the car is new to you, and probably still somewhat unfamiliar.
1 - 8 of 8 Posts
