1 - 2 of 2 Posts
Hey Folks,
1st. post. I have a 12' outback 2.5 with a P1443 code. Any recommendations where to start? I know this can open a can of worms but I'm stuck..car only has 65k miles and it drives fine. And it does fill with gas fine with no problems. And gas cap was replaced too.
Any help
Regards
Yorkbrick
2013 Outback 2.5i Convenience
@yorkbrick I looked earlier and there is no code P1443 that I saw (maybe changed in 2013...). The close ones are for the evaporative emissions system. Google search has many hits for "p1443 Subaru", all emissions. One fellow found that it was a bad valve at the intake manifold, he had a spare and replaced it and the problem gone. I'd check to be sure the connector is ok, might be dirty or disconnected at best and at worst the solenoid bad.
Are there any symptoms when you fill the tank? Hard start? Hesitation? When you fill the tank, do you stop when it clicks or do you keep adding fuel for a few clicks?
1 - 2 of 2 Posts
