Problem solved
There is a wire to toggle the power amp on when the radio is turned on and the wire is on the connector that the harness adapter was not connected to. The wire is Pink, and you need to hard wire this wire to the switched power for the accessories. The power antenna wire does not have enough current to turn the amp on.
