Hi everyone, great site, I purchased a .00 OB not running(326Km) ($600.Can )(car sat for year and a half), ad said timing belt issue. Story was car died on side of road, owner had car towed to garage not sure what work was done at this garage. Owner gave car to his daughter and son inlaw for the cost of towing to their house. Trailered car home, found fuel pump not working, removed pump and got it going again reinstalled. Checked timing belt looks newish, timing marks appear correct( have new Haynes manual). Put everything back together, also installed new spark plugs, cycled fuel pump several times to prime the fuel system. Car will not start, have spark and fuel pressure, even tried starting fluid, car sounds like it wants to fire but will not start. Next I did a compression test, results are cylinder # 1-123 2-147 3-115 4-91psi. I suspect car may have bent valves due to due to broken timing belt. Rechecked compression on cylinder #4 with 10 cc of engine oil, no change in compression. Talked to neighbor who is a mechanic, he said car should start even with bad cylinder, he said recheck timing marks which I have done, they line up like manual says. what do I do next?
