Non-chipped key - available?
5114 15
I'm curious if there is a non-chipped key that I can buy. And are locksmiths able to cut this key? I am aware that this key can't be used to drive. I was going to zip tie it under the car for those very few times that my wife or I accidentally lock the keys in the car. Hard to do with a remote keyfob, but it has been known to happen. Especially with kids.
Thanks for any info.
1 - 16 of 16 Posts
any competant locksmith should be able to cut you a key. Just goto a locksmith and not wal-mart.
I bought a key for my ex's Wrangler a while back that wasn't chipped, (I was unaware of the need at the time) it would unlock and turn the car over, but it would stall as soon as the chip wasn't recognized.
One thing to be aware of though, if you lock the car with the remote and unlock it with a key, it sets off the alarm. I believe you can deactivate it by switching the car on/off 3 times quickly, or by using the keyfob if it's locked in the car ;)
I always have a key somewhere in case the keys get locked in the car. Where I have it, the person getting the key would definitely get greasy and dirty, I hope I don't have to do it with good clothes on on our way to some important engagement.
2011 Subie 3.6R Limited 2013 Cmax e=nergi PHEV
Local locksmith with a sidewinder cutter charged me $27 sans the removable chip which I could buy for another $45. Just need it for emergency entrance to the vehicle. Expensive but better than the dealer valet key.
2016 3.6R Limited
Yea - as others mentioned, any locksmith should be able to help you with getting a new key made. They should be able to chip it as well if desired.
As far as stowing a second "backup" key, this is the solution I use.
I just lock it to my roof rack when I leave my actual keys in the car so they don't get lost/destroyed.
Also my girlfriend uses one of these guys for permanent backup.
Still requires a trip to the dealer if you want to start the car with it.
I don't believe so. I think they can make the key to match the chip in your current key, so the car doesn't know any different. At least that's how I understand it.
2013 Outback Limited 2.5 EyeSight & 2010 Legacy Premium, 2010 OB Limited (traded)
Any ideas where? My last check for this came up with many places that could do this for certain brands but no one could clone a newer Subaru key. Being that the key can't be cloned means that the new key would have it's own ID which would require it to be registered in the car's ECU if you want it to start the car. Registering keys requires the Subie diagnostic tool which so far only the dealer has.
Hide-a-key lock-a-key
I guess you could possibly hang the masterlock padlock from the hitch as well. You can bolt this GE ACCESS POINT LOCK to the hitch too.
It has a high quality rubber cover. Some tapperscrews - primer - and its good.
I haven't tried Subaru specifically, so that may be the case. If so you might as well pay them for the key because they'll charge you as much to program it. I bought an oem remote start a few years back online and it cost $50 more to have them do the full install vs installing myself and having them just program it :rolleyes:
12 OB Prem
I was just thinking about this. Why all the trouble to get an extra valet key made to hide on the car? When we get the car, we get 2 remote keys and a valet key. Who actually uses the factory valet key anyway? Why not just attach the valet key to the car (by your preferred means)?
End of story.
Because I'd rather lose a $5 non chipped key tied under my car than a chipped valet key that will cost at least $100 to buy and reprogram.
12 OB Prem
I guess my suggestion won't work for you guys then. I don't have a remote start (block heater tho), I'm not the type who intentionally locks the keys in the care and uses a spare to get back in at the end of the day. I'd only need the key in emergency situations like:
  • lost keys while hiking
  • car left in lot by spouse and i need to get it home.
Thanks for the input, everyone.
1 - 16 of 16 Posts
