1 - 10 of 10 Posts
00 Outback Wagon...269K 09 Legacy 2.5 Sedan...93k
Hi all...
I have a pair of good 16" snow tires off of a totalled mini-van, but have no rims for them. I know someone who mounted Pontiac Grand-Am wheels on his Outback. I'm wondering what other manufacturers wheels would work so I can keep an eye out for any deals. I'm planning on mounting the tires to the wheels and just changing them in Nov/April. Thanks in advance!
5x100 bolt pattern and an offset close to ET48 for an 01 OB, and you should be okay. I'm sure there are other manufacturers wheels that would fit, you just need to get the specs on them.
2005 3.0 R n totaled
Can you name some on TireRack's website? Thanks....
Hi all...
First thing, a pair or four? You don't want to be putting on just two!
Also, why not Subaru wheels? I can often find sets cheap on Craigslist around here.
the whole hub-centric thing and caliper clearance comes into play too.
On TireRack you just plug in your make, model and year and they'll show you all the wheels TireRack has available that fit. IIRC they are all aftermarket brands though, and I prefer OEM wheels since they are generally more durable. With winter potholes and crappy NJ roads, I've heard many a story of aftermarket wheels cracking.
I picked up my 18" on CL for 300. Discount tire gave me the hub centrics free when I bought the tires.
All kinds of rim deals on CL. Just takes some time to find what your looking for.
Any 5x100 with 45-50 offset will fit. Just make sure the tire is the correct size or it will rub on the strut's spring seat.
That's the first thing I picked up on also! All 4, or none.
2004 Outback Wagon, 2.5, 4EAT, All weather package.
Small GMs used to have that bolt pattern... Cavalier, Beretta, Sunfire, etc. Probably could use wheels from those cars.
And yes, there are 2 reasons why you need 4 snow tires...
1. Your car is AWD and needs to have matching tires on all 4 wheels at the same time
2. I would assume you want to put the new snows on the front since the car is predominantly FWD, this is also a bad idea. NEVER, EVER put 2 snows on the front of the vehicle if you aren't going to put them on the rear as well. Unless you like going backwards and having no control of the rear of the vehicle.
If it were me, I wouldn't consider other brands on a Subaru. Always struck me a strange.
Just keep your eyes out on the forums for people who want to ditch they 16" stockers.
1 - 10 of 10 Posts
