96 Legacy OBW, EJ22 swap, 2" suspension lift, 215/75r15, HIDs, 06 WRX interior swap
Has anyone tried installing an exhaust manifold from a 90-94 legacy 2.2L onto our cars? They are slightly more unequal length than ours and give that nice Subaru grumble I like so much.
Thought it would be a nice cheap alternative to the borla header since they can be had at a picknpull for $35. If its a direct swap I can swap it from a 91 I recently purchased for $300 :)
99 OBW 4EAT, getting built
Did you end up trying this? If so I might have to look for one. I imagine it looks close enough to stock that it wouldn't be an issue for a smog test unless the guy REALLY knew the car.
No I haven't. Picknpull doesn't sell them because the cat is apart of the manifold so they're all cut cause federal law states they can't sell cats.
But comparing the 2 I do believe it would work. You'll have to have an exhaust shop weld an after cat o2 bung and tie it into the OB exhaust which wouldnt be too crazy. No one will hav a clue it's not original unless that specific worker is an OB freak too... We are out there.
I'm assuming it'll still fit under the primitive skid plate as well which was my main thinking for this. I am still unofficially on the lookout for a deal on one and if it happens I'll be sure to post my results with pics pass or fail.
Welding a bung on would't be a problem at all :) there are more than a few welders in my garage.
If Pick N Pull doesn't sell them that makes it more difficult, I wonder where I could get one.
Someone parting one out on Craigslist
