1 - 13 of 13 Posts
2010 Outback 2.5
99 legacy outback 2.5, 235k, recent new head gaskets, original catalytic converter,
have a replacement autozone gascap, that has been in use for prior 3 months, without any codes
after the HG, got a P0420 followed by 2 PO440's, so there are currently 3 codes in my obd reader, listed as fault 02 and pend 01
P0420 Catalyst Efficiency Below Threshold (Bank 1)
P0440 EVAP Emission Control System Malfunction
Thinking gas cap probably ok since no codes since I replaced it a while ago, and probably next step go to smog check place to see if their analysis shows I have a bad cat converter.
Any other ideas to try?
If bad cat converter suggestions where best to get a replacement?
2010 Outback 2.5
Discussion Starter · #2 ·
just realized the 'bank 1' indicates the code is coming from the passenger side head where no 1 cylinder is. if there is a bad cat converter, would it not affect all the cylinders and end up putting out codes for both heads?
Meh.
I has wagons.
Most likely a failing oxygen sensor or exhaust leak.
2010 Outback 2.5
ohhhhhh I hope your right
of course that assumes an o2 sensor is less costly than a new cat converter!
I will trouble shoot for obvious o2 sensor stuff, but if they other wise looks ok, is there any way to test it w/o an oscilliscope? all I have is a decent VOM
Fresh Out of Outbacks!
Keep in mind that many error codes are SAE specified- meaning generic to all makes and models. Pretty sure the 0420 is among them, like all 0xxx codes. Bank 1 would indicate one side of the engine *where applicable* as on a car with separate exhausts for each head. With a merged exhaust like the Subaru, it is simply the default.
You have a bad O2 sensor, a leak in the exhaust, or a bad cat- in order of likelihood. Possibly more than one problem.
I read cardoc's p0420 thread last night. Totally in awe- very thorough. strongly suggest the OP runs off to read it.
2010 Outback 2.5
testing the front O2 sensor
finally got a plug for a test harness and also needed a new DVOM. After reading a number of posts about testing sensors I tried to test sensor while its installed in the front cat. But see pic, the readings just don't make any sense. It seems the front sensor is ok, based on the way I'm reading the codes. Again I have both a p0420 and p0440, when I disconnect the front sensor I get a p0135 which goes away when I reconnect it. My reasoning is if the front sensor was bad it would cause the 420 and 440 so disconnecting it for the test would not change the error codes. Again see pic, could the yellow and white wires be the O2 heater, thus no volt readings on them? Could the black be the wire for the O2 readings and thats why it has the braided shield? to 'shield' it from adjacent wire voltages because its so sensitive? Don't really want to take this sensor out for a bench test, have to take apart the exhaust header pipes just to get at it?
I have the shop manual wire schematic for a 99 outback but there are no wire colors on it
P0440 is often as simple as a leaky/loose gas cap. My father gets that code constantly on his '98 because for some reason he can't get it through his head to tighten it until it clicks.
So, it could be totally unrelated to the other code. Never hurts to check the really simple stuff first! I'm sure we all forget to even try the 10-second fixes before diving into some intensive troubleshooting sometimes!
thinking there could be 2 problems as well, wondering if inspecting the fuel filler neck might be a good idea.
but, given the work done, it's very tempting to suspect a vacuum system problem which 'could' cause both codes I expect.
A vacuum leak will cause both issues. Have you looked into a broken or loose vacuum hose?
And that's a good effort you are putting out. Test first, replace after.
P0440 is another generalized EVAP code. You have to know and understand how the complete system operates in order to track down the issue.
'99 Outback 2.5 GT auto & '97 LegOB w/ grossly insulted 2.5
Just replaced the filler tube on the wife's '99 GT; I was amazed at the amount of rust perforation! I'd recommend soaking the guard retaining bolts with penetrating oil (I like Kroil from Kano Labs in Nashville). This will make it far easier to remove the guard; be advised though that you will most likely encounter more than a pound of dirt, gravel, & asphalt while removing the guard. Ahab the arab headgear helps! Hers had the tube at the top of the filler rusted off & the valve attached to the filler pipe relegated to a fond memory.
I've seen this as well. When I've replaced the filler tube, I leave the guard off unless the customer does a lot of off road driving or gravels. All it does is catch the dirt, salt, occasional road kill debris. The filler tube is heavier than the guard anyway.
It wouldn't cause the 420 code though. Leaks gas or causes an EVAP issue is all.
1 - 13 of 13 Posts
