Hi,
My wife's car, 2006 LLBean 3.0 Outback wagon, has an odd vibration which I can't seem to narrow done. I had the wheels balanced and tires rotated thinking that might be the problem. Nope. Vibration is still there. BTW, the vibration only happens when the car is on the gas and while turning slightly, eg changing lanes, going up hill, following a long bend in the road. We encountered this vibration most at interstate speeds. When the car is at interstate speeds and driving in a straight line, there is no vibration. Again, the vibration only occurs when at speed and turning the steering wheel even a little.
While changing the oil, I noticed that both axle boots were split. Not having a garage anymore, we decided to take it to the shop. The cost for redoing the boots was nearly as much as getting new axles. We decided to replace the axles. When we had the axles replaced, I insisted on getting Subaru replacement parts. I know that they're more expensive, but I try to buy factory parts that the dealers use to avoid cheap, Chinese junk.
Could this issue be caused by the axles or am I over looking something? I'm open to suggestions.
Sincerely,
Heinz
Sincerely,
Heinz
