Kiljoi3130,
The only way you'll know for sure where the oil is coming from, is to pull the timing belt covers and look. Check the many YouTube videos for Timing Belt change vids. Just be sure to watch the correct one for your engine, as some bolts for the covers may be in different locations. The job will be much easier (more room) if you pull the fan assemblies first. Removing the radiator will give you even more room, but may not be necessary. Good Luck!
