1 - 8 of 8 Posts
2005 XT
Changing my timing belt this weekend at 104k. I noticed there was a fair amount of oil on the passenger side, right above the timing cover. It looked like it was related to the power steering pump, but it also seemed more like oil, not ATF (which is what they use in the power steering). Is there a gasket behind the power steering pump? It seemed odd to me.
Dry in the timing belt cover though!
Tom
Discussion Starter · #2 ·
Above you can see the stain on the timing belt cover between the PS pump and the alternator, although, it doesn't appear to be ATF, as I said. There was more of it there before I mopped it up. Some pooling under the pump.
Nope, switch looks dry. Thanks for the suggestion though.
Anything around the pump? It really seems isolated to that area. Maybe the pump just has a slow leak and it looks like oil? Nothing on the head behind it. No noticable drop in PS fluid.
Tom
If the power steering fluid has been in circulation for a long time, it turns brown like oil.
The only thing in that area that would leak oil is the PS pump seals, the banjo bolt seal or the feed hose.
Clean it with a brake cleaner, dry it and run the engine turning the steering wheel a few times then check it again.
Excellent suggestion. I'll try that out.
Tom
As said, ATF can be dark in the pump and then quickly gets black in the environment, picking up dust, debris, etc.
If you're loosing much then you should notice it reading low on the dipstick on the power steering reservoir, have you checked the level?
Power steering pump leaks are fairly common and there are quite a few easy and cheap fixes for them depending where it's leaking.
The level looks good on the PS reservoir. I will try to isolate the leak. I'm more and more convinced it's the PS.
1 - 8 of 8 Posts
