1 - 11 of 11 Posts
2000 Lancaster 2.5L
Hi guys,
Just noticed that along with my transmission oil leak, I've now got an engine oil leak to keep it company. Here are photos of it, its a 2000 outback 2.5L Auto.
My question is, is it worth paying to get it fixed(im no mechanic) or should I just keep topping it up when needed? (hasn't needed yet)
Thanks.
If the leak is just the valve covers its a relatively easy and cheap repair.
2000 Lancaster 2.5L
Thanks Timberwolf, so does it look like a valve cover leak to you?
Can anyone else tell from the photos what is leaking?
I have the same problem with my 2005 H4 engine. All along, I thought it was the oil filter on the bottom of the engine, I would tighten the filter and it would seem to stop leaking. Had I thought it might have been something other than that, I would have claimed it while I still had a warranty.
Now I have purchased a new set of valve cover gaskets, O-rings, etc. which I plan to install. I hope the leak is remedied by that as I hate to think it could be the head gaskets.
i can't see it in the pic, but usually there is an oil cooler that the oil filter threads on to. and there is a large o-ring gasket between it and the block. it tends to leak with age. it cost about $7 at the dealer and takes less than an hour to replace.
that's not the only leak but it is a leak. and it is probably the one leaving a drip in your drive way over night.
Sorry for the late reply, missied your response somehow, I would do the valve cover, spark plug orings, and cover grommets, give the underside of the motor a good clean and monitor further inboard for head gasket leaks.
But it looks like a majority of the oil is around the valve covers, so try that first.
2000 Lancaster 2.5L
Thanks guys, valve cover gaskets it is then. along with the cover grommets and spark plug o rings. Should the gaskets be torqued at a specific setting?
Is there any info out there covering all the torque specs on all gaskets etc for the EJ25?
I'm going to give it a go myself when i get the time, after reading through all the information here i'm more confident that I can get it done without too much drama.
Pdftown and download the almost full workshop manual, I think it's for 2002 though the specs and instructions should be the same.
2000 Lancaster 2.5L
The pdftown 2002 manual doesnt work, links no longer available.
Try the 2000 download, seemed to work for me, but i tried it on my iPad and it hasn't quite finished yet.
1 - 11 of 11 Posts
