Any particular reason why you bother to drain the oil? If you just swap the filter, you won't lose any more oil if the sump is full than if it's empty.
Any particular reason why you bother to drain the oil? If you just swap the filter, you won't lose any more oil if the sump is full than if it's empty.I use synthetic, when I have to swap the filter I drive it up on a ramp, drain the oil through a fumoto drain valve into a 5L jug, swap the filter, and pour the oil back in. It's a money saver in the end.
This junk is quoted all over the web. If you're tempted to give it credence, buy the article and read it for yourself:Engine wear actually decreases as oil ages. This has also been substantiated in testing conducted by Ford Motor Co. and ConocoPhillips, and reported in SAE Technical Paper 2003-01-3119. What this means is that compulsive oil changers are actually causing more engine wear than the people who let their engine's oil get some age on it.
I reset my "B" trip counter to reflect the oil changes, so no math necessary (until I unplug the battery for some reason--like I did this time around to run a power cable for my under-seat sub).I may go to 5000 interval after warranty period only because it is easier for my mind to do the math!![]()
Thanks dude...but did you even bother to read my next post following that one? SEE POST #16. The BIG question is...did YOU buy the article or is what you wrote just from the web also?!This junk is quoted all over the web. If you're tempted to give it credence, buy the article and read it for yourself:
Antiwear Performance of Low Phosphorus Engine Oils on Tappet Inserts in Motored Sliding Valvetrain Test
To me, the conclusion is completely unjustified. This article involves an experiment with an externally powered test rig and an experimental oil formulation, not a real engine with store bought oil. The most important finding isn't that wear metals in general increased quickly at the outset of the test (what was the starting condition of the equipment?), but that lead levels, in particular, rose throughout the test (lead indicates bearing wear). Oil discussions always seem to end up with selective interpretations.
Every engine and driver is different. If your plan is to extend drain intervals, protect yourself and your engine by getting an occasional oil analysis. My opinion, a $20 oil analysis every 5000 miles vs. a routine $40 oil change every 7500 is close enough to break even to make it not worthwhile. Want help deciding? Read the owner's manual.
That's a good idea! The problem is remembering to reset it.I reset my "B" trip counter to reflect the oil changes, so no math necessary (until I unplug the battery for some reason--like I did this time around to run a power cable for my under-seat sub).
I have almost 14k on my '12, and it has not used a drop, Mobil 1 since 1,100 miles.I have a 2010 Outback 2.5 CVT with 32,000 miles and continue to see oil consumption such that I'm adding a quart at 4,000 miles so I can get to 7,500 miles before a change.
I don't abuse or baby this engine, primarily commuting over highway miles.
Anyone else seeing this issue with Mobil1? I'm wondering if I go with Dino oil if the oil consumption will stop.
Have you checked to see if your PCV valve is working?I have a 2010 Outback 2.5 CVT with 32,000 miles and continue to see oil consumption such that I'm adding a quart at 4,000 miles so I can get to 7,500 miles before a change.
Timing chain: imperative to utilize the correct weight oil (0W) now given its affect on the timing chain system. I have utilized "German" Castrol 0W-20 with great success in the past :29:The 2013 Outback came from the factory with full synthetic, but I believe the 2010-2012 came with a blend or conventional oil. The 2013 has a 7500 mile oil change interval, but im not sure on the 2010-2012. I would say go Synthetic. Im considering doing my own oil changes to save on the cost or just letting the dealer do it given that the interval is longer. Autozone had a 5-6 qt container of Mobil 1 as well as Valvoline full syn for around $25-$30. The 2013 with the timing chain engine has the oil filter right on top like the 2012 Forester, so other than pulling the drain plug it should not be difficult. I believe with the ground clearance I dont even have to drive the car up on ramps! What I would say is anything that was created by the earth out of degraded plant matter is no match to engineered polymers made by nerds in a lab with black rimmed glasses and white tape holding them together
That would depend on what you feel comfortable doing. But my answer would be brakes for most people.Im always leary about do it yourself on scheduled maintenance. Other than oil changes which appear to be easy what major things should a certified mechanic look at on the intervals if anything?
Good point. I have been an Amsoil dealer for over 20 years and typically do extended change intervals. However, as a previous poster said, the 7500 mile interval keeps more involved in what's going on under the hood.I've noticed that some people concerned with an additional expense associated with using full synthetic oil. One way to cut down synthetic oil cost you can reduce its cost by eliminating parasites - middlemen.
You can find your Amsoil local distribution center and open customer preferred account with an annual fee of $20. Then you can buy your oil at a wholesale, not retail price. For example, one quart of full synthetic Amsoil OE 5W-30 costs $6.10 but if you buy a pack of 12 then the price will be greatly reduced. You're saving even more if you buy advanced signature series of Amsoil which are more expensive in retail.
