Outback '18 MR1118 with BF AT KO2 245/65/17 Lift kit help?
10964 7
Hello Outback family!
Just got a Outback 2018 in White over the weekend and I am looking to get the Motegi MR1118 with BFGoodrich All-Terrain T/A KO2 245/65/R17 ...
Will I need a lift kit before I install?
Been looking around for Lift Kits and the only ones I've found are LP for 2018.
Anywhere else I could find a Lift Kit available? Just scoping out all my options.
Thanks in advance!
1 - 8 of 8 Posts
2018 Outback 3.6R Limited
Welcome to the family.....
You will not need a lift. I have the same wheels and size tires with no lift... But I am running the Falken Wild peaks.
As for other lift options you can check out Anderson Design Fabricators (ADF).
2016 Outback, 3.6r, wilderness green
Jimusoke
How are the wild peaks? Are they loud tires at slower speeds vs higher speeds? Curious if you have tried them out in the mud or snow yet and how they perform.
Thanks!
@La Rana, the Wild peaks are great, I have not noticed if the tires are louder at slower speeds. Have not tried them out in mud but a buddy of mine has and swears by them. I tried them in snow and they were great....way better than the Bridgestone.
Thanks in advance!
I have this setup on the factory suspension with zero rub.
If you look in the 2015-2017 section in the LPAdventure website, you'll find it there...
There's ADF as mentioned above and I believe Subtle Solutions might possibly offer it as well.
2017 Outback 3.6 Limited with Tech package
I have a 2017 Outback and am also looking at the 245/65/17 TK 02s, My dealer mentioned they were not supported as they altered the wheel diameter by more than 3% which would adversely affect the Eyesight system. Has anyone else heard of this? ... I'd prefer to install the 245s if possible as they fill the look of the car out way better than the stock 225s.
2015 Outback Limited 2.5
Looks great! Any rubbing issues at all with the 245/65 17's?
1 - 8 of 8 Posts
