1 - 2 of 2 Posts
Afternoon all, apologies in advance if I’m breaking rules, not quite sure where to put this as I’m new to the forum.
I’ve owned my outback for 4 months now, just recently (more noticeable in the UK heatwave) my air con has stopped blowing cold air.
I had it regassed at the garage this morning but it hasn’t worked they said it had plenty of gas in and it didn’t seem to be leaking, I changed the fuse for the ac in the cab and the relay under the bonnet but still no difference. I also removed the pollen filter and that seemed ok apart from a few small leaves which I vacuumed out. What do you recommend my next step to be?
Thanks, Mark.
Lawn ornament XT
Just a bit of research first- I don't know what equipment was installed on the euro-spec 2010s.
In the North American market, 2009 and earlier Outbacks have a traditional compressor with a clutch controlled by a relay. 2010 and later use a new always-on clutchless compressor with a variable displacement system- the ECU ramps it up and down as needed. No relay.
It would be good to confirm which system yours has, because the troubleshooting steps diverge from that point.
1 - 2 of 2 Posts
