1 - 10 of 10 Posts
2013, Outback, Limited 2.5
I have been checking the temperature and average fuel consumption accuracy in my 2013 Subaru Outback Limited Multi-function display. I have found the car to be consistently 3 degrees higher (when driving) than the actual outside temperature and the average fuel consumption is always exactly 1 mpg higher at fill-up than the actual gas mileage. Just curious what others have been experiencing.
2011 Outback Premium CVT, AWP, Steel Silver
Same thing on the mileage, always 1 mpg high, I am good with that because I never trust those things anyway. I do the math or let fuelly do it for me.
The temp gauge reads high too, but I don't really pay it much attention.
I used to drive around with the avg mpg displayed all the time but I ended up turning off because it annoyed me and effected how I drive. Now I just look at it just before filling it up and turn it off again.
Also... anyone test what the difference in mpg is when using regular vs premium gas in the 2.5?
2010 Outback 2.5I Premium
Just from personal experience ,and not a formal test :
No real difference between reg and premium as long as the ethanol content is the same . Ethanol versus non-ethanol , noticeable difference .
Since , in my area , it is easier to find non-ethanol premium than non-ethanol regular , and pumps are marked as " may contain up to 10% ethanol " , it can be difficult to truly compare .
After 39,000 miles , would rank gas mileage versus type of gas as :
Non -ethanol best.
Ethanol containing
Non-ethanol winter blend ( at least so claimed as to non-ethanol )
. Ethanol winter blend worst .
From personal experience on a weekly 200 mile round trip using the same route , the difference is a good 5 miles per gal. between best and worst.​
Update: Adjusted my fuel -4% and did a complete fill-up. The average fuel consumption console indicated 27.3 mpg. The actual was 27.2 mpg. Considering the display goes in .3 intervals, it appears to now be spot on.
<O:p</O:pThe outside temperature reading is now low when you first start the car, but after the engine is warm, is very close. I dropped it -2 degrees, but it appears maybe -3 degrees may be closer. The engine temperature definitely influences the reading.<O:p</O:p
2013 3.6 White SAP
Your mileage will be a function of the energy density of the fuel. Ethanol has a lower content per gal. I don't know that premium has a higher energy content per gal than regular. Diesel does.
Depends where you live. Out of the 5 county where I live Premium has no ethanol in it while the mid grade and regular grade have 10% ethanol.
In those areas if I fill up with Premium I see a definite uptick in MPG.
If I use Premium near where I live there is no difference.
I bought an ultra gauge for the OB. Lots of extra gauges that make driving a little more fun too
1 - 10 of 10 Posts
