I installed a new JVC radio about two months ago in my 2002 Outback.
At that time, I connected the blue power antenna output wire on the radio to the correct wire in the Subaru harness so that the Subaru Clarion antenna booster was powered up when the radio was on. Everything was working, and there was good reception on both FM and AM.
I don't use the radio all the time, I mostly play tunes from the USB stick, so I don't know when this happened. I now have no FM or AM reception.
I'm clueless where to start with this. Does anyone know if there are any fuses, breakers, or fusible links to check, or if this is a common problem that will require the antenna booster to be replaced?
And no, I have not pulled the radio all apart yet to check for power at the blue wire, and things like that to troubleshoot. I wanted to know first if this is a known and common problem with the booster?
Thank You! :29:
Lee :gasp:
Thank You! :29:
Lee :gasp:
