I installed a transmission cooler on a 2012 Outback 3.6R.Okay, I've removed my grill. Now what?
Take the old one into Autozone. I saw some there that should work. They may look a little different. Then there is the Stealership they probably have an exact replacement.ChrisJ, thanks to your vid, I was able to remove the grille and install some Supertones. Thanks again!
http://www.subaruoutback.org/forums/452935-post13.html
The only problem I encountered was a broken "popper" fastener... specifically the flat-head screw type holding the air intake duct. Does anyone know where I can pick up a replacement fastener?
Thanks lavarock, I'll try that. In the meantime, I found the part in case anyone else is looking for an exact replacement....Take the old one into Autozone. I saw some there that should work. They may look a little different. Then there is the Stealership they probably have an exact replacement.
Hi Chris: great video! Will it be much different to remove the grill on my 2015 Outack?Hey guys proud to announce I am doing a new youtube channel for Subaru mods! This is the first video of many! Enjoy!
Subaru Grille Removal - YouTube
