1 - 13 of 13 Posts
2018 Outback Touring 3.6R
A couple things of note. Surprising how much damage from the collisions that they show, and also how close the Outback was on one of the RAB examples that they showed. This feature would have saved me $500 a couple months ago on our '11 OB!
2022 Outback Touring XT. Also 1995 BMW 525i with 240,000 miles
I almost sideswiped my other car backing out the garage and the blind spot monitor startled me and caused me to stop. Not sure if I kept going if the RAB would have kicked in. In any case, thank you eyesight.
2019 2.5i Limited Forester (hers) (4th Subie), 2014 Impreza Premium (mine)(#5)
When I'm demonstrating RAB, I use a nylon pillar, so that if it DOES hit, it's not going to cause any damage. Where RAB (and Eyesight) have their limitations is if the driver applies inputs, it can over ride the automatic system. And all RAB systems are not the same. I think they've improved the Outback system from the '17 to the '18. The '17 would stop the car about 1" from the target at a reversing speed of 5 mph. When the '17 Impreza came out, it would stop at 4" from the target at up to 9 mph, and now the '18 Outback seems to do that. It may have just been a change in programming, but I've noticed the difference.
Note and disclaimer - my test results were done on a closed course, with me behind the wheel demonstrating a car to a customer, using a plastic traffic lane post. You may not achieve the same results as I do, especially if you touch the gas or brakes. >:)
2020 Touring XT
There are countless false-positives where the system full engages when it doesn't have to, especially when backing in and out of sloped driveways. It scares the sh** out of everyone in the car, including myself -- but it's okay b/c there was a time it legit saved me from backing into a pole I did not see.
Reactions: Sandbag
85BRAT97SVX03Baja5mtHonda's
They used to make cars with winodws and pillars that were EASY to see out when backing, could see everything 360 degrees out ALL windows.
Maybe the engineers need to pull up some older cars to see how to clearly see out the windows, then design future cars so we can see out them again.
what they NEED to make is a new SVX. with the cool windows. the ones you can not use at a drive up window to get coffee.
Here's a shot I took at the auto show looking out the rear of a new GMC Terrain from the driver's seat. That's one of those cars with a "stylish" flair that turns the rearmost windows in to pillbox slits.
'18 Outback Touring Dark Blue Pearl 3.6r
I see them on the street from the outside and wonder how you can see out the back. A lot of cars disguise the blind spots by tinting the windows dark, One thing I like about both my Subaru's is the visibility out the back end.
Super Moderator
The small overlap frontal crash test ratings are wreaking havoc with new designs, causing the high side window beltlines. Everything is starting to look like a 1930's gangster car.
1 - 13 of 13 Posts
