1 - 15 of 15 Posts
2015 Outback 2.5i Limited.
I have a 2015 outback 2.5. Looking to replace rear window wiper blade. Should I replace entire arm or just blade insert? The current rubber blade is torn. Also, If you have suggestions for make or style that would be helpful. Thanks-J.
It's just your choice.
Laughter is the key to happiness
'15 OB 2.5i, A/T G015's, grey Konig Runlite's, Rally Innovations Light Bar w/Hella Driving Lights
I need one too. I'm going this route as Costco didn't have any 14'' blades.
(Guess I can't post links yet)
Go to Amazon,search TRICO Exact Fit 14-B Rear Integral Wiper Blade - 14 Inch, make sure it confirms a "FIT" for 2015 OB.
You replace the entire blade assy.
Take a look at RainX Expert Fit, they look identical (and may be OEM). IIRC it’s 14”. No need for Bosch/PIAA gold plated types, they won’t make a diff in the rear. You’re better off on a replacement interval, before they tear.
2017 Outback 3.6R
It sure would be nice if Subaru moved the wiper assembly up to the top of the window like the newer 4Runners. The wiper blade is out of the elements up in the rear spoiler.
2017 Outback 2.5i Limited
I'm just happy that the rear wiper arm allows you to move the wiper completely away from the rear glass. My wife's Jeep Cherokee only moves about an inch away from the glass, making blade replacement more difficult.
2012 Outback Limited 2.5
Yup +1. The Trico 14-B was a perfect fit for me. Looked exactly like the original one.
-Thanks for the confirmation. I'll order today.
Confirmed per my maint spreadsheet, Trico Exact Fit Rear Blade 14" 14-B. I remember it looked identical to the OEM.
2017 Outback Touring 3.6R - Pearl Brown
Can't tell if Trico Exact 14-B will work for 2001 Outback rear wiper. Appears to measure 14.5 inches. Anybody know?
2011 outback 3.6R LT. 2015 Outback 2.5 (white) eyesight, tow pakage, skid plate, moon roof
Buy the first one at autozone and they install free . Then you will know from then on.
1 - 15 of 15 Posts
