Overfilled fuel tank -- what to expect
12570 11
Been travelling and pulled into an Exxon station to fill up. I expected the pump to click off at around 8-1/2 gallons, so I slowed the pump rate shortly before reaching that point, as I have done at every fill up. However, the nozzle didn't shut off as I expected, and fuel came out of the filler tube, at which point I let go of the trigger to stop the flow.
I know that this can cause liquid fuel to get into the charcoal canister, but not ever having had this experience before, I'm wondering what to expect, if anything. What experiences have others had when this has happened, either due to a faulty nozzle or by "topping up"?
1 - 12 of 12 Posts
no big deal, happens all the time, i've never heard of it causing an issue and it never has for me before. i travel a lot - twice i've looked out the store window to see a pool of gas around the rear of my car and gas still sloshing out the nozzle/fuel door because it didn't shut off and i often go inside when traveling....i don't condone or recommend that, just saying it's not a big deal.
You would have had to get the filler neck and the overflow tube filled with gasoline for it to get into the canister.
That's what happened. ". . . the nozzle didn't shut off as I expected, and fuel came out of the filler tube, at which point I let go of the trigger to stop the flow." So the tube must have been filled, at least for a moment.
As long as you drive it far enough to lower the level immediately after the overfill, I would not expect there to be a problem. If you drove it 1/2 mile after the fillup, and parked it in your garage, it could contaminate the charcoal canister. But if you drive it enough to use .5 gallons or so, you should be fine.
I could not take it out for a longer drive last night so, yes, it only went a mile or two.
Drove about 500 miles today and no problems. I'll see what happens tomorrow as the car goes through a second full "drive cycle" and repeats the "monitor" tests.
Happened to me with my 2008 a few weeks ago. The pump clicked and I had a whopping 24 cents to go to make it an even dollar (it was a rare time where I paid cash). That 24 cents went on the ground. I was quite surprised it didn't stop a little further from that point, must have stopped at the last possible second! Guess I won't do that again!
I saw no issues. I probably burned off the "extra" on my ride home and I rinsed that area of the car pretty well.
I am a fairly new Subaru ob owner. The guy i bought the car from warned me about filling the tank to the top because it will cause gas to spill out. I thought he was nuts when he said this but it did happen the one time i filled up the car! It really freaked me out! Alot of gas poured out on the ground and it lasted for a while. Is this some kind of design flaw in this car or is something else wrong? Someone did replace the filler neck on my car so maybe they screwed it up somehow?
Sometimes, when the fuel pump head stops before the tank is filled its a venting issue indicating a closed vent valve for the EVAP.
When the pump head does not shut off, its a problem with the pump head, not the car.
Discussion Starter · #11 ·
Update: Another day of driving, fill-ups (with nozzles that work!) and a couple of "drive cycles" -- no problem. So I think I'm on good ground to say it's fine (no problems with the charcoal canister or evap control system), as others had suggested. Thanks for the comments.
1 - 12 of 12 Posts
