Hi, I'm a new member trying to get some help with my 1997 Outback wagon. I know it's old and I know there have been many discussions about HG and overheating but this is my story so far.
I just bought this car about 3 months ago. Had water gurgling in heater core, went to mechanic he suspected HG went back to 2nd hand dealer and got $800 back in order for me to use my mechanic to make repairs. My mechanic replaced thermostat, rad cap, core cleaned rad and flushed system, replaced HG, timing belt and tensioners, water pump, couple of other oil seals. Pressure tested heads and shaved heads. Also replaced top radiator hose and cap several times now. I have spent over $3000.
Car can run great for miles and then start to overheat. Seems to dump coolant in to reservoir and that then overflows, then when it cools sucks reservoir dry and rad needs coolant as well.
Also top hose is collapsing sometimes even while engine running, but I have replaced it and replaced the radiator cap 3 times, overflow tube is clear of obstructions.
May be related to air conditioner as I have only managed to replicate symptoms in garage while A/C is on.
Please help. At the moment I have lost all faith in Subaru and my mechanic
