41 - 45 of 45 Posts
2007 Outback
Discussion Starter #41
481880
i see the green (o2s2 trim) has some fluctuation...
i suppose that (in the legend below the graph) the four at the bottom belong to the front o2 sensor (o2s1, air fuel meter) and the o2se is the second right?
2007 Outback
Discussion Starter #42
uhm... i think i found the culprit...
but also i wanted to mention something first... this car used to give me in totally flat highway at 60mph 28-29mph, after i installed the second air cleaner element charcoal stuff... now i get 33-37mpg, measured exactly at the same part of the road at the same speed, it was very noticeable :oops:.
and the suspect of the p0420 code....
2005 Outback VDC limited 3.0r
That looks like the back of the car correct? Near the part that splits for the mufflers? Anything after the cats won't cause a p0420 code. As nothing measures exhaust that far back. You could cut the pipe right after the cats and you would not end up with a p0420.
2007 Outback
Discussion Starter #44
Hi!
No, it is just behind the passenger's side silencer
482100
and yes i thought the same you mentioned, that is too far from all the sensible stuff like to be detected by any sensor
2007 Outback
Discussion Starter #45
i was doing some pending works in the car and i installed a new downstream o2 sensor.
this is the condition of the old one
482875
41 - 45 of 45 Posts
