I've gotten a lot of help off of this and other forums over the years and might have come across a problem/solution that could be helpful to others.
Car is 2007 Outback 2.5 with just about 200,000 miles. I was getting CELs and very hard starts. I've been having gas cap codes (especially after filling up) so I started carrying a small, cheap code reader to clear those and then one day my cheap code reader wouldn't work any more. I had been using the car on some long trips and often the code would clear by the time I got home and I would forget about it but I tended to notice the hard starts and CEL seemed to come during heavy rains and moist periods. The other day the code remained when I got hom and I tried my big Autel code reader and it wouldn't power up either. Using the external power on it I was able to power up the code reader and get the P1560 code.
I checked voltage at the OBD port (pin 16) and only had 6 volts (it varied as high as 10 and as low as 2). I checked the power at the ECU (B135 pin 5) and also had low voltage there. When I was checking these voltages I was using a variety of grounds to make sure it wasn't a ground issue. I had very low resistance between the ECU and the OBD port but high resistance between the port and Fuse 13 under the hood.
The wire comes from the fuse block and then splits right above the OBD port to go over and feed the ECU. I cut that split out to make sure it wasn't the issue and it wasn't but that also helped me confirm my problem was between the OBD port and the fuse block. I also pulled the fuse block out and checked resistance between the fuse socket on top and the wire pin on the bottom to make sure everything was good there.
Finally I pulled the inner fender off to get access to the harness where it enters the cabin of the car and there was the problem right in front of me. The wire harness makes a corner to enter the cabin and the wire for the OBD port and ECU were on the outside of the harness and had gotten worn through.
If you're having any troubles and it could potentially be in this harness I'd suggest looking there first. I only found one other person (on the NASIOC forum) that had a similar problem (also in moist conditions) but he just ran a jumper wire from his always on stereo power to the ECU which would fix the immediate problem but could cause some issues down the road.
