1 - 10 of 10 Posts
2017, Limited 2.5
For a couple of months now my driver's seat has been a pain in my butt. I had it in the same position for 7 months and about 10,000 miles without an issue. Then suddenly my left leg/butt cheek started to hurt while driving and later.
It seems like it could be coming from the airbag under that bolster on the left side. If I press on it I can feel the frame (or something else that's hard). It's putting a fair amount of pressure on my back side and making me uncomfortable.
I've repositioned the seat up, down, in, out, etc. Same problem.
Thoughts?
03 H6 OBW & 06 WRX Sportwagon
if problems continue, you might investigate back and seating products made by Obus Forme'
good stuff
2015 Carbide Gray Outback 3.6R with EyeSight
Get an MRI done - a herniated disk in L5-S1 pressing on sciatic nerve may cause the pain to radiate down the leg.
2013 O.B. and 2018 O.B.
If your wallet is in your left rear pocket, take it out.
So true. I carry a thick wallet and for years had left leg pain off and on. Since I switched to cargo pants because I carry a lot of stuff, meds, etc. and still thick wallet, several years ago, almost never get any pain, at least not like before. Carry the wallet in leg pocket of cargo pants, NOTHING in rear pockets.
Or go to the dealer and press on new ob seats to compare. If the seat foam on a 17 has broken down ask for it to be replaced. To new for that.
2018 Outback 2.5 Limited with Nav, Premium Audio and Eyesight
Hi Matt, I'm a spine surgeon - and I used to live in North Kingstown. I agree with the suggestion of not wearing your wallet in your back pocket. Another consideration is Piriformis Syndrome - irritation of the piriformis muscle in your buttock that presses on the sciatic nerve. Does it hurt only when you sit in your car, or does it hurt when you sit on other surfaces as well? Also, try re adjusting the settings on your seat. Some people tend to lean back a little too much, so try a more upright position. If in doubt, see a physician and get your back checked out.
David
1 - 10 of 10 Posts
