1 - 20 of 21 Posts
2008 Ford Escape XLS - 2002 Subaru Outback
If you've painted your stock Outback rims, post up a picture! I'm debating on doing mine
Discussion Starter · #2 ·
I'm going with gunmetal grey, with black primer and two coats of clear. I may do a hammerd grey, which is basically gunmetal with some black specs mixed in.
2001 OB, 2.5
did you paint over the clear ? Or how did you prep them? would love to see some more people posting pics. especially gun metal powder coats!!
00 OB 07 OBXT
Rustoleum Graphite metal flake wheel paint.
Clean wheels with paint prep, sand with 800 grit, fill any dings, primer with rustoleum wheel primer, 3 coats of paint at 1-3 hour intervals depending on temp 2 coats of clear. Let them dry for a few days before subjecting to elements if possible.
I taped off the outside lip and sanded it to bare aluminum and polished it before clearing. it's been a year and everything is holding up fine, no peeling or fading. Might paint the other set of WRX wheels I have black, to see if I like those better. Oh yeah, clean the lug holes out well and cover the tapered seat before painting, I used pennies, then popped the out before the paint dried. If you paint the seats, the first time you install the lugs they will chip the paint up on you.
That looks great...much better than the ones that are simply black IMO!
Is your OB at the stock height, BTW? Hard to tell for sure in that picture.
00 OB 07 OBXT
No, about a 1" Baja spring lift.
Wheel isn't mounted in that pic obviously, I've got some others somewhere.... just don't remember what they're on at the moment.
Black is more striking on this color OB, this would look better on a white one IMO. The color on the cap was quite a bit darker than it ended up. I thought maybe the 3 rd coat would help with that but, not so much. metallic "depth" got better.
Oh yeah, make sure to clean and sand the back edge of the wheel so the paint adheres well there.
What I went with doing:
2001 LL Bean
Have you considered getting them powder coated? I did a spare set for my old Mercedes wagon, and they turned out really good. They have a super durable finish too.
Discussion Starter · #11 ·
I'd rather spend $20 and have to do it every tire change over then spend $200 on $150 rims. Heck. I doubt these rims will see 5,000 miles in my ownership.
2001 Outback, 2.5L
Did mine semi-gloss black and painted the grill to match. I sanded and used a steel wool pad on the rims first, then added 2 coats of auto primer and 3 coats of black auto paint. It's a rattle can job, but for the cost (about 15 bucks) and about 4 hours I think it turned out really nicely. It's been about 8 months now, and I have yet to get a scratch/peeling/or nick.
2002 Subaru Outback
I did my wheels almost 8 years ago and has not shown any peeling from Duplicolor Graphite. I coated the wheels with 2 coats of primer and 2 coats of Graphite. Note the cap on rear drivers side rubbed on a snowbank one winter and that is the only one showing signs of wear. Otherwise, been really please with the color.
Discussion Starter · #14 ·
What do you have for tint?
2002 Subaru Outback
Just the standard 35% tint, nothing special. I do not recall the brand though.
Discussion Starter · #16 ·
It fits the car so perfectly IMO.
2001 Outback 2.5 with 5 Speed
I tinted my white 01 with 15% on all windows except the windshield, and its perfect! Not to dark, but just enough to keep the sun out. I just realized that this picture makes it look a little dark, but its not nearly as dark as like 5%(limo) would be.
I think I want to paint my rims that Graphite color, It looks really nice on the red car. All black reminds me of a car with plain old steel wheels, but that Graphite lets them look stock yet custom. A coworker is doing his soon, so I'll wait until he gets his done and I'll give it a go.
Discussion Starter · #18 ·
Anything darker would really really pop being a white car. Black would almost be to much, but a lighter grey would even look amazing. My Gunmetal would be to dark. I am thinking about doing 35% in the front windows and on the rear windshield, and then doing 15% in the rear side windows.
01 Outback base
One guy on here used plastidip spray to do his rims, any thoughts. i like that it is removable and would only require cleaning to adhere, however short it might last. Hey, could you spraypainting over that stuff? you might be able to experament with different colors.
Discussion Starter · #20 ·
You can get many different colors of plasti-dip. It lasts about 6 months, and honestly isn't that removeable if you leave it on there to long.
1 - 20 of 21 Posts
