1 - 2 of 2 Posts
Hello,
Subaru Outback 2010 3.6R
3 bulbs in a passenger side headlamp assembly don't work:
1) Low beam
2) Side parking bulb (covered by an orange cap)
3) Front parking bulb (small bulb inside the same assembly).
Checking all 3 bulbs most likely would require removing the whole assembly. Would it?
I am reluctant to do so as symptom looks to me like some kind of fuse (all 3 bulbs are in the same assembly).
All fuses located in engine compartment.
Are there any fuses related to parking lights at all?
Should remove assembly to check mentioned bulbs?
'15 Outback 2.5i Premium
It's very unlikely that all three lamps are on the same fuse. The ground wire may be the common element. A ground problem might keep all three from working.
1 - 2 of 2 Posts
