wow nice hit - those flats that line up with the shaft? i've never thought to look and put that together, but i've never had a broken pump yet either.
nice pic's - was that hard to get it to focus down there? showing off your skills!
Yeah, they line up with 2 flat spots milled to the end of the piece that engages the outer part of the converter.
No talent here, just an iphone and perseverance. You can tap on the screen to tell it where you want to focus, and it focuses on that spot.
Those things have quite the lens, it's a dual-liquid electrostatically adjustable unit.
Dave, you should keep this all on one thread. All this jumping around must be making you tired. You should save your energy for putting the trans in. :29:
And yeah, the iPhone takes great HD too.
I will consolidate, the problem is if I have a very specific question and I stick it at the bottom of my trans replacement thread, it doesn't get noticed as well.
Hey, if I just pop the lower ball joints (and tie rods too if it'll help) can I get the front axles off the stub shafts without taking the outer CV joint out of the hub?
I think there's enough room.
01 Outback LL Bean
All you need to do is remove the front lower control arm bolt and you should be able to get enough room and play to remove the axle from the trans output shaft.
